Central, IA | I have a Miller Nitro 7410 with a Raven RCM module run through an Ag Leader incommand over ISO. When filling, I get a little water in the tank and start the pump to provide agitation while filling. I can control the pump and agitation valves from the ground near the fill.
If I suck product in through the inductor and don't shut the valve quick enough, it seems to suck some air and the pump loses prime. This sets off an alarm on the display in the cab and I have to climb back up there to reset it. It makes agitation while filling almost impossible. Is there any way to shut off this alarm that shuts the pump off? | |
