Posted 5/16/2023 17:50 (#10231699 - in reply to #10230558) Subject: RE: When to tedder thick hay after rain?
SW OH
That works here. If the ground is wet it won't dry if covered with hay. Tedding will stir the hay, but if the ground is wet the hay will attract the moisture from the ground.
