Search Forums | Classifieds (222) | Skins | Language
Trimble pro 600 offset
torn
Posted 5/3/2023 10:49 (#10214342 - in reply to #10214172)
Subject: RE: Trimble pro 600 offset
roaming
swfarmer - 5/3/2023 07:29
Have a pro 600 on our 4wd and the it seems to over lap 3 feet on 1 side and leaves a couple inches gap coming back. Have the offset set at zero. Looks like the trim is set to .39?Any ideas? Only Trimble unit we have. Just using waas
The Pro 600 is a Case IH display, not anything from Trimble. Are you using a Case IH receiver like a 252, 262, or 372? Is the receiver mounted on the cab left/right centerline? Check all of your setup values first (Toolbox > GPS > GPS Right Offset should be 0). Then disconnect from your implement and do a good roll cal. If the tractor drives well by itself after the calibration, then connect to the implement and try again. If the problem is gone, then you're good. If the problem comes back when you connect the implement, then check your implement measurements, offsets, etc. From your description, it sounds like either a setup or calibration issue. Could be something trickier related to implement draft, etc, but check the simple stuff first.
A Trim of 0.39" should not cause the issue you're seeing, but if you don't know why it's set to .39, then zero it out.
