| Trying to do a calibration on a JD 8400. Same system as last year. Only difference on the tractor is I put the bigger hyd pump on it this winter. During the cal process for kickout I turn the wheel half turn line instructed. High point is set. Immediately the high point numbers on the screen start to drop. It won’t stay engaged to continue the Calibration.Bad pressure transducer on the valve? When I turn the wheel I can see the high point numbers increase like it should with pressure. When I’m not turning the wheel is when the high point numbers drop off. Example: high point set at 18500, then drops to 10000. Wheel angle sensor counts seem normal. Thanks for any help.
Edited by semnjoe 4/30/2023 07:49
