Search Forums | Classifieds (110) | Skins | Language
Manage fields with MyCaseIH software
Tractorman1
Posted 3/17/2023 20:56 (#10145480)
Subject: Manage fields with MyCaseIH software
NC Iowa
I would like to combine two smaller fields into one larger field. Mainly the guidance lines (not any applications)in each of the two fields I would like to merge into one field. I’m struggling to find a way to combine or merge these two fields. When I try to edit the field or the guidance line, the software will tell me that that field already exists. I have tried renaming each field and also using a new name. I have a fair amount of lines in each one of these fields, because of its odd shape. Some of the lines are curved lines like following a dredge ditch. I think I could manually create new lines in the new large field manually, because it shows me the coordinates, but I don’t know of a way to do the curve lines. I realize I could just make all new lines in the field, but I’ve spent a fair amount of time getting the lines that I have now the way I like them.
I am using Pro 700 with RTK. I have several red tractors with one blue tractor with Intelliview 4. I have uploaded all my lines from each tractor and I’m also trying to make a master list so that each tractor has the same lines. I have not used any other software programs to do this. Last fall I did do some of the lines for an experiment, and although I found it a little clumsy to use the software, it did work pretty well.
Anyone have any experience with the Case software? Any ideas would be appreciated
Andy
