northern Mi | A shear type head can be put on an excavator. A processor head that cuts tree down and can process into 8 ft lengths will be very expensive unless it is basically wore out junk. A processor head works best on tall straight trees without a lot of limbs. The type of trees growing on fence line are usually big, bushy crooked and have a bunch if iron in them. I think you could heat with propane cheaper and less work. Rip out whole trees ,push into a pile and burn. | |
