Southern MN | If the compressor pumps, which it obviously does, I would just get an inline check valve and put it on the outlet of the compressor. Should be 6mm or 1/4" push to connect. Like this: https://www.norgren.com/us/en/detail/c00gl0600 You can just cut the tubing and push it all together.
Your local fluid power distributor will have them. Not sure what state you are in, but if you let me know I'll tell you who to talk to. | |
