Posted 9/25/2022 21:57 (#9861204 - in reply to #9860594) Subject: RE: Case IH combine 2-way radio interference
We mount our 2 way radio antenna s on the mirror brackets on our 7230 combine & Magnum tractors. Never had an issue with interfering with out GPS signal or 700s. If you go that way you'll need a non ground plane antenna. We tried the factory antennae base / cable on our first flagship , 7010, & on olf Magnum tractor but reception / output was terrible.
