Search Forums | Classifieds (210) | Skins | Language
FarmTRX - Exporting issues
FarmWeather
Posted 8/1/2022 17:26 (#9776057 - in reply to #9776010)
Subject: RE: FarmTRX - Exporting issues
Delta
jpucheu - 8/1/2022 15:47 Hi guys. Trying to get data out of the Farmtrx cloud. Tried exporting raw points to ag leader SMS. It imports well, but there is no grain flow data, and the swath value is always the same. So I can't run the optimize swath width filters, and no matter what ag leader SMS settings I use, can't get dry yields totals right. Tried the same route with the corrected yield maps, in point or raster versions, and the data was garbage. Used the ag leader advanced format export option to use the USDA yield editor, but the long and lat fields have too many decimals and crash the software. Edited the file to round numbers, yield editor loads it, but the grain flow data is unrealistic and after some filtering it crashes. The "corrected yield map" export option outputs cleaned data, but after an examination, there are a lot of problems that get cleaned with my usual USDA yield editor procedure. Any ideas? Thanks
I have not worked with the FarmTrx cloud, but if you send me some data I can take a look. By the sounds of it you are quite capable, so I doubt a find anything. Just offering.
