Posted 6/29/2022 13:34 (#9726632 - in reply to #9726213) Subject: RE: Semi air valve problem
under The maple tree
Build up full air with the red line attached to a trailer abs valve in the in position. Unhook the gladhand, if the red valve doesn’t keep the air tanks from draining below 60 psi, it’s not working right
