Fargo, ND | It might be possible if the Switch Box supports the AUX-N standard, as does the sprayer, and the connected ISOBUS display, and the boolean latching functions of the switch box are the same as what the sprayer is looking for.
If you're planning on using the armrest C1000 display, I've been told it supports AUX, however, I've never personally tried it. I believe the Integra will support AUX-N (I know the InCommand will), but you will need to make sure it is setup as UT #1 on the tractor. Only the primary UT display can support AUX. | |
