Older Wilson DB pro not boosting cell signal
simple man
Posted 6/23/2022 19:43 (#9718256)
Subject: Older Wilson DB pro not boosting cell signal
I have this older unit with outside Yagi antenna and two indoor antennas that will not boost cell signal anymore. I disconnected the splitter and tried indoor antennas individually and neither one receive better signal. I think the splitter is ok. Both high and low indicators light up green so the device seems to work ok. Haven't tried a different outside antenna. Indoor signal show -123db which is 1 bar on my phone. Standing near the outside antennas the phone shows -104db which is 4 bar strength. The old Wilson has the high and low frequencies so figured it would still work with the newer 4g and 5g. Anything else I can check out or do I just need to upgrade to a new booster. What do you think?
Thanks
(20220617_171117_copy_924x2000 (full).jpg)
(20220617_171129_copy_924x2000 (full).jpg)
Attachments 20220617_171117_copy_924x2000 (full).jpg (176KB - 216 downloads)
Attachments 20220617_171129_copy_924x2000 (full).jpg (138KB - 221 downloads)
