Posted 6/14/2022 09:45 (#9704680 - in reply to #9700709) Subject: RE: Raven Correction levels and Unlocks
Butterfield, MN
Right VSN would probably be the best. Otherwise, Satellite GS Pro or RTK would probably be good enough to hold between the rows, but that means it would have needed to have been planted with the same guidance lines, which isn't always that simple to make happen, especially when going between different technology providers that use different type of guidance line geometry.
