Posted 6/1/2022 08:06 (#9685651 - in reply to #9685268) Subject: RE: Odd 2630 mapping problem
SE SD
There is nothing wrong. The GPS is just changing direction of travel. If you backed into the corner and dropped the planter without pulling forward a little ways first, recording has started and the last motion was in reverse. It's knowing it needs to turn around, doing a 360 degree turn ,thus the gap and overlap.
