I ran the calibration program on the Pro 700 but I'm not happy with the results. I think it is under applying about 4%. I want to adjust the CAL number to correct this. Do I need to increase or decrease the CAL number to increase the flow rate.
Tag on flow meter CAL # 190. CAL # in the monitor is 179 after running the calibration program.
Rate is 5 gl/ac. Fertilizer is 3 gl 10-34-0, 0.25 gl Zinc, and 1.75 gl water.
