Posted 6/2/2022 10:19 (#9687398 - in reply to #9679450) Subject: RE: Raven CR7 to Viper Display
Butterfield, MN
There isn't an adapter harness, as far as I know, but it should be possible, as long as you also replace the console cable with a different one. Also, the Viper 4 will need the ISO section control unlock to make it function correctly with the Hawkeye 2 if the model you get doesn't already have that feature unlocked.
