Search Forums | Classifieds (225) | Skins | Language
correction switching between rtk and omnistar problem
pjv
Posted 5/16/2022 07:44 (#9662569)
Subject: correction switching between rtk and omnistar problem
North west Il.
I am having an issue running agleader insite with a trimble 372 and nav2 controller. I am running this system on RTK but every time the tractor is shut down and then re started when we power up the insite and want to activate auto steer we get a message vbs subscription has expired. so when i go in to gps setup screen in the drop down box for receiver type it will have reverted to 132 instead of 252/332 that i have selected prior ( have to select this receiver type as 372 is not in the drop down list) and my correction type changes from RTK to another correction type. I have tried selecting auto configure but it will not work also tried selecting manual configure and i can configure the system and it works as it should which is great but then if the tractor is shut down and re started the the receiver type and correction type switch back to 132 and get that vbs subscription expired message. any suggestions Thanks Phil
