| mine has been an excellent tractor, too good in fact, been adding feet to the tillage equipment and all of a sudden a wet year happens by. Now it seems a little light. Mine has 5500 hours on it, filters oil and grease, every day grease the articulting u joint, every couple of years change out the fluids(trans, diffs and planetaries) I am the second owner and have put on about 250 hours a year, amazing little tractor, but remember it is small by today's standards...... but in the same token it is pretty light on fuel except when you are overworking it.... If it hasn't been abused there should be no problems......... IF | |
