Posted 6/12/2009 22:34 (#743162 - in reply to #742518) Subject: RE: CaseIH 7240 hyd problem
Southeast MN
With the rear tires on 60" centers, there's not much wiggle room under the cab for checking things over. When you say it goes dead, do you mean it works for a while then quits? That would be an odd one. Could it be a bad cable from the lever to the valve body?
