Bonanza, Or | I have a set of hyd hay rakes that uses both sets of remotes on my JD 6410, one remote to run the baskets and one to run the functions. The problem is that when you engage the remote for the functions which is set to open center it builds pressure even when the flow control is turned down. If the other remote is engaged to run the baskets and you engage the function remote it will speed up the baskets alot.
I have switched remotes and that made no difference. This tractor has the 200 series remotes and I found this article http://www.deere.com/en_US/ag/servicesupport/tips/tractors/common_s...
Any ideas what is going on here? | |
