Elkmont, AL | Thanks for informing me about the shorter bolt on the new hub. Would have probably put it all back together before I realized that the bolts are different, saved me some time. Case dealer had all the parts except shorter bolts, and no one in town had a shorter bolt of the same size and grade, so I shimmed the bolts with some washers and used a little loctite. You would think case would make the bolts part of the update kit. Back up and running by 11am, cut a grain cart full and rained out. | |
