NESD | I'm not familiar with a 5460 but am familiar with the 619, will the oil pan come off without pulling the engine? If it can it would sure help in finding the source of the leak, as you have been told it could be the oil cooler, head gasket, a liner cavitated thru or a liner o-ring leaking, by having the pan off and pressurizing the cooling system would allow you to watch where tha anti-freeze is coming from. Hopefully it is the oil cooler since that would be the easiest to replace. | |
