Posted 6/10/2009 11:22 (#739672 - in reply to #739651) Subject: Re: 1200 planter
Brazilton KS
Yes. I had to tighten all of the bolts on the front of the parallel linkages on ours. The rear ones were fine. The front ones are reversing lock nuts and the rear ones are toplocks. If they get loose again, which I expect they will, I will be replacing the junk locknuts with some which actually work.
