Search Forums | Classifieds (33) | Skins | Language
Mediacom wi-fi issues
golfnut
Posted 1/3/2022 10:41 (#9415945 - in reply to #9413963)
Subject: RE: Mediacom wi-fi issues
Central Nebraska
I did a few minutes of research on the products you are using.  Why are you using the Eero?  Your Hitron modem/router has built in wifi.  When you setup the Eero did you disable the wifi in the Hitron?  I would suspect your issues are related to wifi interference.  While it is possible to have multiple wifi signals being broadcast in the same area special care needs to be take to make sure they are not on overlapping channels.  Also, are you broadcasting both 2.4 and 5 ghz signals?  Are both bands dropping connections?  The fact that a reboot temporarily solves the problem also supports interference issues.
