Huntington, IN | A while back, someone posted a design to reposition the left front tire of the early models of these mowers. Anyone know where I can find that again??? I am still having trouble with my mower cutting that tire track. I have tried 3 different styles of blades, had my engine turned up, tried different heights and speeds, and still have that damn tire track that isn't cut even with the rest of the grass. The new ones have that arm moved out a bit to fix the problem. So far, Deere has given me a set of high lift blades and turned my engine up but neither has solved the problem. | |
