Posted 6/3/2009 10:52 (#731449 - in reply to #731167) Subject: RE: 9170 slips into neutral
Fought same thing for 2-3 years. As stated check all connections you can find, alternator voltage, etc. Ended up replacing the trans controller eventually and finally fixed it - expensive, but you do get the skip shift.
