Central Missouri | You want a coupe as opposed to a tractor mount if you can afford. Get a 40 series or newer for the power and the 400 gallon tank. Nice thing about them is they are light weight and chain drive rear end which allows you to put wide tires on for flotation. I have 3 sets of tires. The standard 12". A set of 9" for running tramlines and a set of 31" for flotation. The only bad thing I can think of off the top of my head is that the cab is fairly noisy. | |
