Ayr Queensland Australia 4807 | Had to diagnose a hitch problem on a JD 4960 today the machine had caught fire a couple month ago and the circuit board was replaced. I noticed that the2 screws that secure the multi plugs onto the circuit board were not original one was also missing after I worked out that one of the diodes was failed and fixed that I was putting the board back in looking to use the screws used before I noticed if the screws were put in they may cause a circuit change. I would say the original screws were burnt. JD parts say special screw in the description has anyone ever noticed if the screws have insulation washers on them. |
