Eastern VA. No such thing as too many Magnums. | Get your pontoons out a little ways from the pump for more stability. Put the suction screen directly on the pump intake and stand the pump up with the impeller down. No more priming or check vavle cause the impeller stays in the water. You have to have a cover over the motor cause they're not meant to sit butt up like this.
(2034.jpg)
Attachments ---------------- 2034.jpg (116KB - 44 downloads)
