Search Forums | Classifieds (34) | Skins | Language
JD 3155
billybob
Posted 5/30/2009 08:34 (#727458 - in reply to #727165)
Subject: RE: JD 3155
68340
I have the 3255, same set up.  It is the largest utility tractor JD made.  Just rememeber it is a utility tractor and you will be ok.  Have about 4,000 hrs on mine.  JD had a slave clutch cyl up date on mine.  Did it years ago.  Still have 1st clutch in mine.  Have the 265 loader on mine.  No field work was done with mine.  No repairs to date.  Just have to take your time with gears and using the clutch and you will be ok.
