WI | What are you trying to do...if you are just mapping then you would use a connect cable to your RS232 port on the back of your raven. Its like a 7 pin port that is oblong and silver. If you are trying to replace the raven then Deere won't support that- I'm not sure how the Hagie spray system is works but it is definitely possible to do by installing the GS2 Rate Controller- you would need a little bit of time and possibly some harness modification to get it to work. To just map with though is like a 5 min job-super easy. | |
