Posted 5/27/2009 11:52 (#724533 - in reply to #724428) Subject: Re: 4700 Solution Pump Won't Run-HELP!
NESD
I assume you have checked the connection to the proportional valve, if it is not connected it would not show any amps on pump control. Have you done any welding on the sprayer? Not at all common to have a controller fail, I checked availablility and it shows 34 at PDC in Milan, ILL. AN206585
