Posted 5/26/2009 13:06 (#723418 - in reply to #723358) Subject: RE: conditioning roll clearace adjustment for a new holland 1496
Sioux Center, Iowa
You need to have MORE than enough tension released because as soon as you lift the roll, it takes up the slack. Then stick something between the rolls. Chaff and dirt tend to build up in there and mess up your roll gap too. I recommend checking shims and dirt buidup every cutting.
