mowrystown ohio sw ohio | That is a $50.00 front end . It had a undercut setback on it and the back bolts came out bushhoging and went up thru the oil pan and crack block up to the head. the quick works better on the the plows for some reason dos't brake the pins. the motor is out of a 7300 white combine was a petty easy change. we have 2 oliver with narrow on them a 1655 also. handly around the barn and backing wagons around. | |
