Western Oregon | After posting my frustration with AGCO I'm pretty sure they sent someone out to run the batteries down on our "Heritage" line of AGCO orphans. Took me an hour to get everything started and then the 2-155 started leaking hydraulic oil again.
When we started the season it would not lift the strip tiller. I checked the hydraulic pressure and it was 2000lbs at the outlets. I took the relief valve apart and the little shim washers were worn out. Nearest replacement was Fresno. Found some grade 8 standard washers and replaced the little shim pack. Boosted the relief back up to 2400lbs and set compensator to 2200lbs hope that is how you do it cause it's done.
Now I can lift the strip-tiller.
(agco_revenge.jpg)
Attachments ---------------- agco_revenge.jpg (72KB - 54 downloads)
