Posted 5/23/2009 23:58 (#721319 - in reply to #721152) Subject: Re: JD 1900 air cart capacity
I see no reason you can't put 250 lbs per acre with 60 feet but not sure if there will be quite enough fan to blow it out that quick. 7.5 or 8 mph would probably work but not sure about 10
