| Anyone running a new air seeder and having problems with the gs 2 2600 screen. Mine will mess with my guidance and also mess with my seeding rate. I have a double shoot cart and am trying to blow fert on the front rank 15 inch and middle tank blow milo 15 inch back rank. Hopw do you set this up. Haver talked with deere and they cant fix it. Anyone else with problems. If you set it up the way they want it doubles your rate. Just wanted to know who else is haveing the problem and if sdo how did they fix it. Thanks | |
