| I put one in ours last year and ran it all season, this year we moved it to a case 2290. I can't tell you the exact settings we used, but I remember checking the tie rod ends for play and making sure they were tight, also check the steering cylinder right in front of the cab to make sure the mounts and pin are not wore and loose. Make sure the EZ is set up for a self-propelled sprayer and not a tractor. Sorry, I'm not much help on the other settings. | |
