NE SD | Have a hypro pump and the motor on it is getting so hot I can't lay my hand on it. I just got this sprayer. Rear end in tractor is also very warm. I have the return going to one of the bigger couplers up top of scv's. Have pressure into remoted #3. Flow is about 35%. Sprayer is working ok. I had the return going into the scv but still seemed to get hot there also. I am sure its something simple. There is some fittings going into the pump and I thought they were restrictors of some sort but dealer says they are just there so motor can't run in reverse.
Thanks for any advise | |
