Posted 5/20/2009 02:23 (#718895 - in reply to #718534) Subject: RE: Can steiger Puma run JD 1850 air seeder?
NW Washington
Tractor data says it is a closed center system with a flow or 27 gpm. If you have a JD cart I think the fan takes 15 gpm, but you will also have to deal with the JD "active hydraulic downpressure" system on the openers. My guess is that you will be OK if you get things plumbed correctly.
