Southern Saskatchewan | 140/70/140 is right on the money.As for a sensor relearn,disconnect all sensors and prompt a sensor relearn on your monitor.Then as the monitor asks for each sensor,plug them in one at a time (helpful if someone is in the tractor to tell you what sensor its asking for)-very simple and it will take you a whole ten minutes. If other problems I'm sorry I do not have the voltages in my mind.All the sensors should be a width of a dime away from the shaft.Hope it helps-don't worry I've been there. I'm sure Bourrassa's should be able to answer more in depth questions.Good seeding | |
