| One of our air seeders is ran with a 9250 that had the pump cranked to 350hp ( not by us) and it has always ran warm when putting alot of fuel through it, but today was a warmer day and engine temp. got up to 90 C, about 200F and the coolant temp light came on. Is that a little low for it to be coming on. I think most of the heat is coming from the hyd. cause were running 2 carts so its got more product and farther to push it. Manual says 88C to 99C is the operating range(190 F to 210F). Could the light be coming on to early. I ran it with the light on for an hour, and temp peaked at about 94 C. and then felt the engine rad to see if it was overly hot and it wasn't, nor was the resevoir or the cap. So my question is if this temperature is to hot to run or is the light coming on too early. Thanks for any replys
Daylate | |
