Queensland, Australia | Make sure you check out the Mac Don D60-D. The reel and suspension are unreal and definatley better then on the mid west. You can shave the ground with the hyd adjustable fore and aft tilt. The guide wheels work well with the lateral float but I don't think anyones guide wheels come near deeres set up with the airbags. Another thing to watch is the width. A mid-west is 40 ft from crop divider to crop divider where as the mac don is 40 ft "effective cut". It's just something to keep in mind if trying to compare apples with apples. | |
