Posted 5/17/2009 14:49 (#716470 - in reply to #716231) Subject: Re: 85 COE semi
Like already mentioned it could be in the rears. If that turns out to be the case, has one set of duals locked up in a stop at sometime? Is there a flat spot on a set? If so you can reduce the effect somewhat by offsetting/rotating the the flat spot on that set.
