| I suppose somewhere, an injector failure caused a problem down belowfor someone. For what it is worth, I have never seen it happen. That claim will cover a lot of years and more brand names than I can quickly recall. Here is what I have seen that might cause this:
- Parts dirty/damaged during assembly
- A sudden load on a cold engine
- Coolant in the oil
- Overheat
- A worn cam lobe on that cylinder or anything else that results in short valve lift will do this. { Do check this on a 400 series IH- either valve. It will overheat that cylinder }
- Piston spray jet plugged
- Oil pressure low.
- Wrong liner to block o-rings, or using petroleum based lube to install silicon rubber o-rings
- Damage to the liner bore in the block. .... I used to do some follow-up repairs for a guy who would brag about not needing a sleeve puller to overhaul his customer's engines. His tools to remove sleeves consisted of a length of 3/4 inch shaft, and a four pound hammer. All was well until age got the best of his vision. Then he would "miss" with the driver and kiss the block with a big dent right below the o-ring grooves. This slight damage to the lower area of the block would be enough to distort the new sleeve into an eggshaped condition. The first time a good hard load was applied, the results looked just like your pics. I know this sounds crude, but I could usually fix this with a die-grinder, a lot of cleaning, and one new piston/sleeve. | |
