Posted 5/14/2009 17:44 (#713484 - in reply to #713474) Subject: hold out for the versatile
wahpeton, nd
owned a brand new 1505. It was the biggest POS of a tractor I have ever seen. The cat motor with the broken crankshafts(3times), fan into the radiator, broken transmissions. shaft between engine and transmission causing problems. most of these are low houred tractors because you can't keep them running. stay away from it!
