Posted 5/11/2009 00:43 (#709813 - in reply to #709710) Subject: RE: MT765 challenger hydraulic detent kicking off
Blue Earth, MN
More then likely, you are running the oil reservoir out of oil. Check your plumbing. Are you running a vacuum planter? If so, make sure you are returning the vacuum motor(s) return lines back to the valve stack. Any motor case drains must be returned to the implement case drain return coupler.
