Posted 5/11/2009 09:21 (#709998 - in reply to #709140) Subject: Re: JD 4240 Fuel Pump Question?
Geuda Springs, Kansas
This is probably the case as IH SMOKE said. However since the filter is empty and you may have sucked some air, you will probably have to crack open a few injector lines and bleed the air out before she will run again.
