Search Forums | Classifieds (80) | Skins | Language
hydraulic experts needed, mount on trailer hitch type plow keeps breaking.
   Forums List -> Where Can I find?????Message format
bankshotone
Posted 12/30/2017 17:34 (#6465139)
Subject: hydraulic experts needed, mount on trailer hitch type plow keeps breaking.
Central Iowa
Rear mounted plow. I've done everything I can think of to keep this from happening.
The problem is when the plow is lowered and pressure is applied to scrape and the contour of the ground changes causes the truck to lift in the air and subsequently puts an excessive amount of weight on the plow mount which is just a 2 x 2 tube cobverted to a solid 2 x 2 bar. Both have broken. Is there anything that can be done to relieve the excess pressure when the weight of the truck is on the mount?
