Search Forums | Classifieds (20) | Skins | Language
Cummins 3.9 or 5.9 bellhousing and flywheel
   Forums List -> Where Can I find?????Message format
seedcleaner
Posted 7/5/2017 22:08 (#6107917)
Subject: Cummins 3.9 or 5.9 bellhousing and flywheel
Mid-Missouri
I am looking for a an industrial SAE 3 bellhousing and flywheel for a 3.9 Cummins. It should be the same as a 12 valve 5.9. The flywheel I need will be used for a bolted on splined coupler, not a clutch. The bellhousing needs the starter on the right side of the flywheel, when viewed from the flywheel end.
